Guest Anonymous Posted August 22, 2001 Share Posted August 22, 2001 I was recently given a 305 bottom end that was balanced &blueprinted and has all new parts. Can anyone tell me if I can use the 441 casting heads with the 1.94 valves? I can get these heads with a fresh valve job along with a cam lifters, intake,and Edlebrok performer RPM manifold and carbuerator for 350$ from a friend. I'm not real sure if these heads will work on the 305. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted August 22, 2001 Share Posted August 22, 2001 Les, The combustion chambers on the 350 - 400 sbc are larger than the 305. The 350 heads will not work, but I think if you get 305 heads the inlet will work. Tim Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted August 23, 2001 Share Posted August 23, 2001 just my .02c, I'd take those heads/intake/carb/cam and flip the 305 bottom end and put the 305$ towards a 350 bottom end. Bores too small on a 305 to open up those 350 head valves much and your cc will be shrouded. The inverse of putting 305 heads on a 350 CAN be a cheap budget racing punch for higher compression/racing fun that's common among some budget fbody racers but not great for street (quite high comp AIR). Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 23, 2001 Share Posted August 23, 2001 The only reason for the 305 idea was I got a COMPLETE bottom end with all new parts for damn near free $50. The owner was going to use this engine for a circle track car but decided to move into another division therefore using 350s. He owed me a favor for some work I did on his house so when I told him I was looking for a smallblock for my77 he mentioned the 305. I do know he won a lot of races in the class he raced in and wasn't tearing down engines every4or5 races. Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted August 23, 2001 Share Posted August 23, 2001 Check the casting numbers on MorTec http://www.mortec.com/castnum.htm If they are: 3932441....69-70...350..........76cc chambers 3932441X...69-70...350/400......80cc chambers On a 305 you will have no compression unless you use pistons with very large pop-up's. Sorry but I would pass BTW, Trickflow Aluminum 23 degree heads have 2.02"/1.60" valves, 64cc chambers and will fit a 305 CID SBC http://www.trickflow.com/product/prfeature_index.htm oooooooooooh - light and fast. Quote Link to comment Share on other sites More sharing options...
