kevingorby Posted May 31, 2010 Share Posted May 31, 2010 Hi guys. Need to pick your brains. I have picked up a nice 5 speed tranny and was told it was out of a '78 or '79 Z. I want to swap it with the 4 speed original. I was told it would be a direct swap, but I have found 2 differences with the 5 speed right off the bat. First, there is a sending unit with 2 yellow wires located near the shifter on the right upper side. Second, the speedometer cable attaches on the left side (instead of the right side) with a 45 degree down angle. The 5 speed serial number is 7Y04342. It is stamped ZL 71B with a #1 stamp below that. Your help is appreciated. Kevin Quote Link to comment Share on other sites More sharing options...
ModernS30 Posted May 31, 2010 Share Posted May 31, 2010 Hi guys. Need to pick your brains. I have picked up a nice 5 speed tranny and was told it was out of a '78 or '79 Z. I want to swap it with the 4 speed original. I was told it would be a direct swap, but I have found 2 differences with the 5 speed right off the bat. First, there is a sending unit with 2 yellow wires located near the shifter on the right upper side. Second, the speedometer cable attaches on the left side (instead of the right side) with a 45 degree down angle. The 5 speed serial number is 7Y04342. It is stamped ZL 71B with a #1 stamp below that. Your help is appreciated. Kevin http://forums.hybridz.org/index.php?app=core&module=search I promise this has been covered. Quote Link to comment Share on other sites More sharing options...
