rust under battery tray
I went to work with a grinder and a chisel and cut out the battery tray and the damaged area underneath. I'm sure this is a pretty common problem. Has anyone else encountered this , and how did you fix it? Can a patch panel be bought to repair the body under the tray? Im planning to move the battery to the back anyway.
I haved two with rust so I HAD them cut out & but a box added lower in the car ( even with frame rail ) to lower center of gravity at the same time it takes more time but cooler in the long run. Take care NOT to use a big battery and DO'NT get it in the way of the wheel clearrace. rockon.gifhail.gif2thumbs.gif
