dschock Posted June 16, 2010 Share Posted June 16, 2010 I've got a '71 z with the type A 4 speed badly in need of replacement or rebuild. I would like to either rebuild it, or upgrade to a 5 speed. I know that the type A is an inch farther forward than the newer ones, so I would have to modify the shifter. Would I need a different drive shaft? What generation 5 speed would you guys suggest for a swap in terms of gearing and compatibility? My other option would be to rebuild my 4 speed. I have found rebuild kits at drivetrain.com and zcarsource.com. The kit at drivetrain.com seems to be for a type B, but says 1970-73. Has anyone used drivetrain.com and know how legit they are? The kit is definitely cheaper there than z car source. Thanks for any advice! Quote Link to comment Share on other sites More sharing options...
Xnke Posted June 17, 2010 Share Posted June 17, 2010 The type A and type B transmissions are equal in length, the driveshaft length is different because of the position of the differential. You can swap out for a type B transmission with no issues. Quote Link to comment Share on other sites More sharing options...
dschock Posted June 20, 2010 Author Share Posted June 20, 2010 Are the F4W71A and F4W71B 4 speeds the same internally? I seem to only be able to find rebuild kits for the type B. Any suggestions as to where I can buy a rebuild kit? Quote Link to comment Share on other sites More sharing options...
Xnke Posted June 20, 2010 Share Posted June 20, 2010 No, they are not internally the same. You won't find a rebuild kit easily for a type A, however there are some porshe type syncros that are reported to be suspiciously similar. There are a few threads in here about these boxes, and rebuilding them, but it would be easier and cheaper to swap in a type B box Quote Link to comment Share on other sites More sharing options...
dschock Posted June 20, 2010 Author Share Posted June 20, 2010 I've been offered a FS5W71C from a 1979 280zx. Is this a direct bolt in as well? Anything I should worry about before I buy it? Quote Link to comment Share on other sites More sharing options...
dschock Posted June 22, 2010 Author Share Posted June 22, 2010 Installed my 5 speed today. Everything works perfectly. Thanks for the advice! Quote Link to comment Share on other sites More sharing options...
cody ethridge Posted June 24, 2010 Share Posted June 24, 2010 I have a 5spd in my 75, obviously its not factory, how would it know what type of trans it is and where would i find a rebuild kit, also would it be more benificial and cheaper for me to just find another 5spd trans, ive got 4sps i could put in it but id rather have a 5spd. also i was reading earlier that the earlier 240s have shorter driveshafts. If this is true could i put a t5 from a zx wit a short drive shaft? Quote Link to comment Share on other sites More sharing options...
