Fuel pump removal (harness connector)
Im removing the fuel pump in my 78 280z. Ive removed all the fuel lines and loosened the clamps. The FSM says to disconnect the fuel pump harness connector. It says to roll back carpet behind the seat (which i did) and to disconnect the wiring. How do you do this? I see two different sets of wires. Im guessing one set to + and one to -. But how do i disconnect them?? Thank you
  • 6 months later...
usually behind the passenger seat there is 2 wires one is black and
the other one green each one has a connector that goes to the fuel pump
just unplugg those two and you are done....
