trwebb26 Posted June 29, 2010 Share Posted June 29, 2010 Got an 83' turbo motor that has been sitting for 10 years - reported 60K miles - turns over with no problems. I've already got a good alternator, starter, thermostat, intake/exhaust/turbo setup, plugs, wires, refreshed dizzy, megasquirt, proper fuel, etc... I just need a good reliable longblock. I've purchased: - ARP head stud kit - Water Pump - Oil Pump - Brass Freeze plug set (the ones in the block are rusty) - Timing Kit - Full Gasket Kit The plan is to take off the head to get a look at the cylinder walls and take off the pan to get a look at the bottom end. I'm only going to loosen the mains / rods if something looks fishy - at which time I'll end up buying more parts. The questions: 1) Would you do anything to the head while it is off? I thought about removing/cleaning the valves and replacing the valve seals and maybe giving it a quick gasket match job. Should I do it... don't bother? 2) Would you replace anything else on the lower end while it is this far apart? I'm trying to avoid the expense of new pistons/rings, rod and main bearings, rod and main bolts, and machine shop work... That stuff adds up to a lot of money (and time at the machine shop) - especially when my power goals (less than 350 HP) should be just fine on a "stock" bottom end. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
steve260z Posted June 29, 2010 Share Posted June 29, 2010 I'd test the compression before anything....then you can fix any problems with the motor apart. Quote Link to comment Share on other sites More sharing options...
k1evo2 Posted July 10, 2010 Share Posted July 10, 2010 Got an 83' turbo motor that has been sitting for 10 years - reported 60K miles - turns over with no problems. I've already got a good alternator, starter, thermostat, intake/exhaust/turbo setup, plugs, wires, refreshed dizzy, megasquirt, proper fuel, etc... I just need a good reliable longblock. I've purchased: - ARP head stud kit - Water Pump - Oil Pump - Brass Freeze plug set (the ones in the block are rusty) - Timing Kit - Full Gasket Kit The plan is to take off the head to get a look at the cylinder walls and take off the pan to get a look at the bottom end. I'm only going to loosen the mains / rods if something looks fishy - at which time I'll end up buying more parts. The questions: 1) Would you do anything to the head while it is off? I thought about removing/cleaning the valves and replacing the valve seals and maybe giving it a quick gasket match job. Should I do it... don't bother? 2) Would you replace anything else on the lower end while it is this far apart? I'm trying to avoid the expense of new pistons/rings, rod and main bearings, rod and main bolts, and machine shop work... That stuff adds up to a lot of money (and time at the machine shop) - especially when my power goals (less than 350 HP) should be just fine on a "stock" bottom end. Thanks for the help. welll im doing just about the same thing. another thing i was looking at doing was add replacing valve springs. just want to keep freshing up the top end of the motor too yaknow. Quote Link to comment Share on other sites More sharing options...
