Need some help with MM rear brake upgrade.
I have the 240sx rear disc brake upgrade from MM. I made sure the calipers are on the correct side, with bleeders facing up. I switched the parking brake arms around, but it still seems that the parking brake arms are going to contact the body if I hit a bump. I actually cut off the stock brake line mounting points to get more room. Am I doing something wrong? I looked at the install pics many times, but nobody mentions this problem. Here are some pics. Its hard to tell in the pictures but there is only about 1-1.5" till there is contact.
