rb diagnostics help
gibbon
hi guys, my loom has had all its "unnecessary" plugs trimmed off of it... that includes the diagnostics pins that youre supposed to plug in order to get a code out of the check light. ive got the pinout so i know what pin is what, but i was hoping someone could help me through pulling some fault codes without the aid of the plug and check light.
so question time, i know that theres a diagnosis transmit and recieve wire, and an engine check light wire. if i bridge the TX and RX wires, and run the check light wire through a bulb to ground, will i have recreated the check light system?
thanks in advance
Edited by gibbon
There should be a separate wire for the check engine light. It should connect to a low wattage bulb, then to ground. I'm using the choke light in my 71'. Works great. For the Nissan Consult connections do what others have suggested, get a plug fromt he junkyard and splice it into your harness.
