Need help with this part a few pics
Whats up guys a few weeks ago my temp gauge wasn't working. At first I thought I just had a bad connection so I cleaned all the plugs but still no luck. So them after I went ahead and check the water temp sensor and found this CIMG0025-1.jpg
the loose cable seem to becoming from what I believe is the water temp switch but im not sure. If you look closely you will see 2 small green spots were looks like cables were coming out of. CIMG0028-1.jpg
I was over on zcar.com and I came across this thread but on the pics I didn't see that screw that I have the arrow pointing at.
http://www.zcar.com/forums/702926/280z-question-newb
second picture with white arrow pointing is the water temp sensor. since there is no information about your car, i assume you have a 75 280z. I had this problem before. took me a while to find that switch. good luck
here is my picture
Edited by theguppies
here is my picture
one wire is ground and one wire is connected to the lose wire in your first picture
