Noddle Posted July 28, 2010 Share Posted July 28, 2010 Hi, I'm in the process of re-wiring my MS II system, including my fuse / relay box, and I'm wondering if I should uses 1N4004 diodes to enable flyback on the relays I'm using, or am I'm been to paranoid about it. Nigel Quote Link to comment Share on other sites More sharing options...
goodoldjam Posted July 28, 2010 Share Posted July 28, 2010 I think you shouldn't have to worry about it, V3 boards had built in flyback circuits. Learned a bit from talking with Jacob about his fan circuit. Basically only time you need to add one is when you add a new transistor circuit. If you did need to add some, your transistor would have already failed. This is a very cool read. http://www.autoshop101.com/forms/hweb2.pdf Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted July 29, 2010 Share Posted July 29, 2010 The V3.0 flyback circuit is for the injectors. Using the diode is a good idea. Quote Link to comment Share on other sites More sharing options...
goodoldjam Posted July 29, 2010 Share Posted July 29, 2010 (edited) The V3.0 flyback circuit is for the injectors. Using the diode is a good idea. Now I'm thinking I need to do it. So The Fuel pump relay is going to need a diode then. So does the relay board have diodes in place? Edit: Answered my own question nevermind. I see on a one of your DIY writeups that you added a diode for IAC. Edited July 29, 2010 by goodoldjam Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted July 30, 2010 Share Posted July 30, 2010 The relay *board* does not have a flyback diode in place, but there is a flyback diode for the fuel pump relay on the main board. It's a somewhat different type as it uses a zener diode to pull a voltage spike to ground rather than running the voltage spike to the 12 volt plane. Quote Link to comment Share on other sites More sharing options...
