5/8" hi temp silicone hose for turbo oil drain
OhBilly
Have you tried schucks or napa? Do you have a house of hose or similar place in your town?
I hadn't, but just did. Our local hose supplier didn't have anything, and napa's hose is only good to 200 deg F. Good tip though, thanks for pointing out what should have been obvious to me... check local first.
Im not sure if you have a welder but it might be feasible to just buy some metal fittings and run a steel line from the oil drain tube to the oil pan. You could buy the fittings and weld them on to each of the metal tubes and then screw on the metal line.. Youd have to check with your hose store for prices. Might be just as expensive or more expensive but you wouldnt know till you checked. haha
