ukcats07 Posted August 24, 2010 Share Posted August 24, 2010 (edited) Okay, so this is really frustrating me. My 302 was given to me over a year ago as a longblock with nothing on the frontside. No brackets, no accessories, etc. Block is mid 70's (from a Falcon I believe) with a timing cover that fits a reverse rotation water pump (driver's side inlet). Now the alternator brackets that I have are the triangular piece that bolts to the water pump and the curved slotted piece that's used for tightening the belt. These won't work with my water pump. I have been searching and searching to find out how to mount an alternator to a 5.0L with the driver's side inlet water pump. From what I can tell, I'm going to have to find a JY with a 5.0L and grab the aluminum bracket that a stock tensioner mounts to. It's either that or use spacers to make the current mounts work. I'll try to post pics here in a little bit. Can a stock alternator mount (for say an 89 mustang) be bought at a parts store? edit: This is the bracket I am in need of This is the bracket I have This is the water pump and timing cover that I have FWIW I have serpentine pulleys (probably matters for spacing) Edited August 24, 2010 by ukcats07 Quote Link to comment Share on other sites More sharing options...
ukcats07 Posted August 24, 2010 Author Share Posted August 24, 2010 (edited) So I stopped being cheap and decided that $90 was worth not thinking about this problem. I ordered this alternator mounting kit from Summit and I'm going to mount it low like this guy did I have an idler pulley bracket that I made that puts an idler pulley right above the water pump--similar to 74_5.0L_Z. Don't know why the pictures are rotated 90 out. Oh well, head-tilt chin lift method works. Dont forget to treat for shock. Always...treat...for...shock. Wait, that's self-aid buddy care...nevermind. Edited August 24, 2010 by ukcats07 Quote Link to comment Share on other sites More sharing options...
