milo Posted September 7, 2010 Share Posted September 7, 2010 I was wondering if anyone every use this turbo header and if there was any clearance issues or cracking? I want to use a Percision T71 turbo w/ this header. Any info would be helpful and thanks. Quote Link to comment Share on other sites More sharing options...
g00kb0i Posted September 8, 2010 Share Posted September 8, 2010 I dont believe the obx clears the distributor. The XS power manifolds clears the distributor witha 67mm. http://store.driftmotion.com/static/i-2jzgena-t67mmturbokit.php I know for sure the boost logic manifold will clear the distributor for a 71. http://www.boostlogic.com Is this for a Z car ? Quote Link to comment Share on other sites More sharing options...
milo Posted September 8, 2010 Author Share Posted September 8, 2010 (edited) I dont believe the obx clears the distributor. The XS power manifolds clears the distributor witha 67mm. http://store.driftmotion.com/static/i-2jzgena-t67mmturbokit.php I know for sure the boost logic manifold will clear the distributor for a 71. http://www.boostlogic.com Is this for a Z car ? Yes on a Z31, but I do not believe that the 2jzgte came with a distributor. Edited September 8, 2010 by milo Quote Link to comment Share on other sites More sharing options...
g00kb0i Posted September 8, 2010 Share Posted September 8, 2010 that is true. I for some reason though you running the GE like me Quote Link to comment Share on other sites More sharing options...
Overkill Z Posted September 29, 2010 Share Posted September 29, 2010 Those waste gate pipes are prob goinna have to be cut off and re welded pointing more towards the motor. They stick out way too much Quote Link to comment Share on other sites More sharing options...
ozzzzz Posted December 9, 2010 Share Posted December 9, 2010 I was wondering if anyone every use this turbo header and if there was any clearance issues or cracking? I want to use a Percision T71 turbo w/ this header. Any info would be helpful and thanks. I have one on my build. As stated prevously the wastegate pipe had to be cut shorter and I welded a v-band on. http://s1096.photobucket.com/albums/g335/ozzzzz1/ The picture is on the first page. Quote Link to comment Share on other sites More sharing options...
