Need help with alignment problems
I need help with my 73 240z, I have a z installed with billet lower control arms fully adjustable and t/c rods also fully adjustable
My problem is after the alignment, the control arms are different lengths, 11.5 and 12.25 the smaller one gave me a -1.2 camber and the longer one i was only able to get a -1, it pulls to the right even with a laser alignment(the side with the longer arm) Are the stock control arms differnet length? The mechanic told me it seems like the crossmember needed to be moved over but it is not adjustable right to left on one side it is able to move forward and back a little Is there a way i'm not seeing to correct this problem the numbers for the alignment are Camber LEFT-1.1 RIGHT -1 Caster -4.5 BOTH SIDES Toe in .05 BOTH SIDES
