noobie Posted September 13, 2010 Share Posted September 13, 2010 I'm very new to car stuff and just got a 280z. I'm young and need advice. i just did a compression ratio on the car and all cylinders were between 140 and 145. Is this a normal range? Also the car seems to be running a little rich. I'm going to try and clean the fuel injectors with a treatment. Is there any recommendations of one that has worked for you? I was thinking of using seafoam. Quote Link to comment Share on other sites More sharing options...
Meph Posted September 13, 2010 Share Posted September 13, 2010 sounds about average, new engine should be around 170+ consider rebuilding below 130. Did you have the throttle wide open during testing? Quote Link to comment Share on other sites More sharing options...
noobie Posted September 13, 2010 Author Share Posted September 13, 2010 No it wasn't wide open. I think the car has about 178k so I guess it's not too bad. I just recently picked up the car because th body is pretty straight. Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted September 13, 2010 Share Posted September 13, 2010 There are a few very experienced Z guy's in the Portland Oregon area, I'm sure they will either reply here or you can find them. I'm sure they would be willing to help you out. They are pretty cool guy's since some of them are Administrators on this forum. Quote Link to comment Share on other sites More sharing options...
