Installed Coil overs. but have to lower right front 1" more than left.
So it took me 8 months to finally get all my stuff together and install my coil overs. I did it correctly and used the mr2 rear struts in the front and stock in the rear (illuminas) I sectioned the struts accordingly (about 1.5 inches front and almost 2" rear) i installed everything today and set the threaded sleeve hight so that the upper centering hat sits snug against the upper mount, and was going to adjust from there. but when i put it on the ground, I have to lower the front passenger side 1" lower than the front drivers side for them to be even. I measured the collars, they are at the same height. I looked at spring numbers, they're placed correctly. Im just curious why i need to lower the passenger side almost an inch so its even with the drivers side? is it a weight issue? less weight on the right side? Im fine with that, just wondering if this is normal?
looking for a quick reply? any help much appriciated. thanks!
Edited by simple
