power door lock actuator
greghassen
I've searched and searched for pictures of how other people installed their power door lock actuators in the s30 and never came up with any pictures. I couldn't find a way to fit the big aftermarket actuator inside the door without interfering with the window and giving the actuator linkage a straight pull. Actuators will not last long if they are pulling at an angle. One other thing is to use loctite on the linkage screws because they will loosen up without it.
The big cheap actuator is shown in this picture
In my other S30 i used a actuator out of a zx and it worked out ok. I was able to install it almost directly above the door lock. It wasn't easy but i think the nissan actuator will last longer than these cheap aftermarket ones. But, if anyone is using the aftermarket ones here is a picture of one that was installed by a shop that did alarms. I was replacing the door panels in my new 78 and thought id'e take
a pic to help others out there.
Edited by greghassen
