bumble zee Posted October 11, 2010 Share Posted October 11, 2010 My brother has a RB25DET with a series 2 wire harness and has developed a miss when initially getting into boost. After a few misses it runs like a raped ape. I cant hear any ticking under the hood. His boost pressure is sitting at 7 to 8psi. His tach isnt hooked up yet so I dont know the RPM's. He had a mechanic friend look at it and he said the o2 sensor looks to be bad. It shows .02 volts before boost, then after it drops to 0. If he disconnects the o2 he said it runs a little better but still has the miss. It isnt anything intrusive. Nothing like a shutter that I get from time to time in my Turbo 240z. Quote Link to comment Share on other sites More sharing options...
pat1 Posted October 11, 2010 Share Posted October 11, 2010 Coil packs are breaking down. Quote Link to comment Share on other sites More sharing options...
bumble zee Posted October 11, 2010 Author Share Posted October 11, 2010 Coil packs are breaking down. That is interesting since his coil packs are cracked and silicone is a temp fix so he can drive his car while saving for new coil packs. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted October 12, 2010 Share Posted October 12, 2010 Does he have a consult port? I had a similar issue in an SR20DET. It was the MAF maxing out and dumping a bunch of fuel at torque peak. Quote Link to comment Share on other sites More sharing options...
