Car won't run well with IAT other wise great
JSK
I got my megasquirt running well using a map setting moby provided from metro. Thanks! Tweaked it some. Had to do a lot of researching ugh because everyones application can be different.
I'm running a completely stock setup l28 turbo with optical dizzy.
Okay my problem is when I use the iat the car runs very rough and unbalanced and won't rev. Is there is a simple explanation to my problem and a table I need to configure. Other wise without it it's an abolsute upgrade over oem!
I'm using ms1 extra v3 board. Thanks again!
Edited by JSK
Hello Matt thanks for your response. My timing is way off on the motor lol when I advance it it retards it. Let me go over my timing alignment and see if this resolves any of my problems which I'm sure it will. I had a hell of a time getting it started this morning when it was 30 degrees out.
