Hood Vent Covers
I'm looking for suggestions on keeping water out of engine compartment. Forum search didn't result in anything that was very helpful. 280Z hood, standard vents, SBC engine. Not concerned about rain getting in when car is in motion because air should be coming out of engine compartment, but am concerned about water coming in while car is parked. I can't be the only one with this issue. The stock under vent blocking plate doesn't appear to be a solution, it just routes water to a different but equally undesirable place. Has to be a better solution than using plastic bags!
In comparison, I think those vents would significantly reduce water entering the engine compartment. I wonder if they would look okay to be fitted on the underside of the hood in the same orientation to give a more sleek look..
