zgeezer Posted November 4, 2010 Share Posted November 4, 2010 Has anyone used the JCI air conditioning kit on a truck engine using the LM7 crank pully. I have a ls1 alternator mount that I have mounted on the truck block. it lines up with the truck crank pully. The block was drilled and tapped and the ls1 alternator bracket is spaced out 3/4 of an inch. It appears to line up well with the truck water pump. The question now is: can I use the JCI a/c mounting bracket? G Quote Link to comment Share on other sites More sharing options...
