240zBoy Posted November 4, 2010 Share Posted November 4, 2010 So I have a msd6al ignition newly hooked up. Problem is when I turn it off the car keeps running til the bowl is empty in the carb. Now I know it needs a diode sometimes with the msd ignition so I hooked it up but still stays on. I installed a jumper with the diode within from the large power terminal to the farther of the two terminals. It stays on. I do not have an idiot light or voltage regulator as the manual applies it to, so anyhelp would be appreciated. Or letting me know how you installed it would be great to. -Thanks Quote Link to comment Share on other sites More sharing options...
240zBoy Posted November 4, 2010 Author Share Posted November 4, 2010 Think I'm gonna try a dual ballast resistor. Cross my fingers Quote Link to comment Share on other sites More sharing options...
MikeBZ Posted November 5, 2010 Share Posted November 5, 2010 (edited) Use a switched relay to power on the MSD, like a relay for a fuel pump or fog lights. The relay is opened when you turn the key off and that should kill all power to the MSD box and shut the car off. You could also install a toggle switch that could double as a theft deterrent since the car will just crank and not fire with the switch off. Edited November 5, 2010 by MikeBZ Quote Link to comment Share on other sites More sharing options...
240zBoy Posted November 5, 2010 Author Share Posted November 5, 2010 (edited) I dont mind adding another switch since I have the fuel pump on one. But I would rather not have two switches and just one would be great. Any recomendations on how to install the relay and sizes? New to relays so just wondering. Edit: Nevermind, Pops got home and taught me. Will be trying it out tommorow. After reading other sites it should work so I will get back with hopefully some good news. Edited November 5, 2010 by 240zBoy Quote Link to comment Share on other sites More sharing options...
stwrangler Posted November 5, 2010 Share Posted November 5, 2010 I dont mind adding another switch since I have the fuel pump on one. But I would rather not have two switches and just one would be great. Any recomendations on how to install the relay and sizes? New to relays so just wondering. Edit: Nevermind, Pops got home and taught me. Will be trying it out tommorow. After reading other sites it should work so I will get back with hopefully some good news. use a bosch relay and use the factory key on to trip the relay that way there is no switch. Quote Link to comment Share on other sites More sharing options...
MikeBZ Posted November 5, 2010 Share Posted November 5, 2010 use a bosch relay and use the factory key on to trip the relay that way there is no switch. Yes, use the factory wiring to trigger the relay so the key will kill the power, Autozone sells a relay in the fog light section for 5-6 bucks. Quote Link to comment Share on other sites More sharing options...
240zBoy Posted November 6, 2010 Author Share Posted November 6, 2010 Hooked it up and now it won't start . 85 to ground "Maybe its not a good ground source I dunno" 86 to the 12v source of my ignition "Hot when key is on" 87 to the msd small red wire 30 to the battery. Something must be wrong here as it should atleast start. Please help me!!! Quote Link to comment Share on other sites More sharing options...
MikeBZ Posted November 6, 2010 Share Posted November 6, 2010 85 goes to 12v source of my ignition "Hot when key is on" 86 goes to ground 87 to the msd small red wire 30 to the Battery Should work now If not try a new relay, you might have damaged the 1st one when the wires were crossed Quote Link to comment Share on other sites More sharing options...
