jays280zx Posted November 13, 2010 Share Posted November 13, 2010 Two weeks ago I tried to start my car and got nothing. -the battery shorted (went from 13ish volts to 0)as soon as I turned the key to start. I've checked the battery, the starter, and the posotive and negative cables on the battery. -Now the battery shorts (same thing), as soon as I turn the key to ACC. Any thoughts? Quote Link to comment Share on other sites More sharing options...
WaiDai Posted November 20, 2010 Share Posted November 20, 2010 Two weeks ago I tried to start my car and got nothing. -the battery shorted (went from 13ish volts to 0)as soon as I turned the key to start. I've checked the battery, the starter, and the posotive and negative cables on the battery. -Now the battery shorts (same thing), as soon as I turn the key to ACC. Any thoughts? check fuses, check ground points, clean contacts, wireing. use a voltmeter/multimeter to check if there is a current between connector and some point on the wire. just because the wires are together doesnt mean if there is a current going through them. if that fails, then i dont know what to tell you >_>. in your case a multimeter or volt meter would be your best friend Quote Link to comment Share on other sites More sharing options...
