Z-carforlife Posted December 3, 2010 Share Posted December 3, 2010 Hey guys, Just got my Pallnet Fuel rail thought it was an 11mm rail but its a 14mm rail (as my injectors fall out). I really want to use these injectors, so does anyone know of adaptors? or will running a larger outer diameter o-ring work? If not what are my options in a 14mm without getting into Machining the intake? Please let me know what i can do here guys, if not i might just resell the rail Quote Link to comment Share on other sites More sharing options...
Z-carforlife Posted December 6, 2010 Author Share Posted December 6, 2010 Really no comments out of anyone, i have searched and can't find much info on this. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted December 6, 2010 Administrators Share Posted December 6, 2010 Don't know of any 14mm-11mm bushings, sorry. I have not heard of or know if thicker wall O-rings/square rings can be used successfully to allow the 11mm injector to be used in a 14mm rail, sorry. I would be skeptical of trying it as that leaves a bit of rubber O-ring exposed that over time as the fuel pressure fluctuates could end up cutting the O-ring at the injector? Not sure that would happened, but something I would be concerned about. I know you mentioned you don't want to machine the intake manifold but if you are open to that option, it opens the door for TONS of injector flow rate options being the most common fuel injector with tons of available used injectors for cheap. Some shops have the reamer that will open the Z intake manifold to accept 14mm O-rings, which we happen to have. Shipping back and forth between Oregon and Canada may be expensive, unless you have local shipping contacts across the border from you. Quote Link to comment Share on other sites More sharing options...
napship Posted February 12, 2011 Share Posted February 12, 2011 On 12/6/2010 at 8:44 PM, Z-carforlife said: Really no comments out of anyone, i have searched and can't find much info on this. What kind of injectors do you have? You may want to sell either your fuel rail or your injectors. Quote Link to comment Share on other sites More sharing options...
