Graphitez Posted December 29, 2010 Share Posted December 29, 2010 (edited) Hello, A few weeks ago i removed my gas tank from my 76 280, my plans were to do a full tank restoration. I took a look down the filler neck and to my surprise there was basically no rust inside what so ever. The tank on the outside had a bunch of surface rust, so i sent it out to be sand blasted. When i got the tank back it looked great, no visable holes or anything. So just to be on the safe side i capped of all the fittings,and i made a filler neck cap with a valve stem. I filled the tank with 10PSI and then began to do a soapy water test. I spent about a 1/2hr doing this and found nothing. I then prepped the tank to apply POR15(semi gloss black)to the outside. I applied 1 full coat to the whole tank,a few days later i went to put a 2nd coat and found a leak right near the fuel feed nipple(little bit of gas left in the tank),it had eaten the POR15 completely around the fitting. There was a hairline crack in the Braze(weld)that mates the nipple to the tank, So that brings me to my question, What is the best way to fix this? I am pretty sure they brazed fittings on back then,It looks like solder not a mig/tig weld. I was thinking taking a torch to it to blend(re-braze)in the crack,Or would a little bit of JB weld do the trick? Edited December 29, 2010 by Graphitez Quote Link to comment Share on other sites More sharing options...
Snailed Posted December 29, 2010 Share Posted December 29, 2010 It's best to strip the area and bring it a shop that can braze it and leak test their work for you. I would try a radiator shop first. Leave a hose running in it for a while to flush out any left over fuel, then run air into it for a few hours to dry it all up before you bring it. Quote Link to comment Share on other sites More sharing options...
Graphitez Posted December 30, 2010 Author Share Posted December 30, 2010 It's best to strip the area and bring it a shop that can braze it and leak test their work for you. I would try a radiator shop first. Leave a hose running in it for a while to flush out any left over fuel, then run air into it for a few hours to dry it all up before you bring it. Thanks for the info,now the hard part is finding a radiator shop in my area. Quote Link to comment Share on other sites More sharing options...
