rusted frame rail
Nismo280zEd
Never thought it would happen to me but it did! saw some major rust breaking through from the floor board down through the frame rail there is about a 2" hole now in the back of the driverside frame rail... i know alot of you have dealt w/ this i was wondering the best thing to do to reinforce? i was thinking like welding almost like a cover over the whole rail? yeah no?
welding around rust produces a lot of spit and sputter. If you can get to solid ground around rhe rust --go for it with a welded on sheet metal patch.... If you want to cheat...clean it up and pop rivit the patch on or carefully tape the bottom and use fiberglass over it... or consider making a rotissire..
