akumazedex Posted January 6, 2011 Share Posted January 6, 2011 Quick question, do I need a turbo dizzy for the turbo engine harness or can I use my na one? Also will the na dizzy to oil pump shaft work on a turbo oil pump? Thanks. Quote Link to comment Share on other sites More sharing options...
MikeBZ Posted January 6, 2011 Share Posted January 6, 2011 On 1/6/2011 at 9:24 PM, battlesquaddatsun said: Quick question, do I need a turbo dizzy for the turbo engine harness or can I use my na one? Also will the na dizzy to oil pump shaft work on a turbo oil pump? Thanks. You'll need both the turbo distributor and shaft, the NA stuff wont work with the stock turbo harness and ECU Quote Link to comment Share on other sites More sharing options...
