Error in Cylinder Head Temp Reading
azZdriver
I am using MS2 and the relay board. Even with the cylinder head temp sensor removed I am getting the same false readings. It reads 0 degrees F then jumps up to the sixties randomly. I have also posted over on MSEFI.com but have not found the solution yet.
OK I tried a few things: new wires to sensor, replaced vacuum hose to MAP sensor, reset MS2, put the settings in again. The erratic behavior is gone, however my temp reading is over 160 on a cold engine. Also there is a typo above, forgot to type the negative sign, my settings are:
2490
-10c/14F=9K ohms
20c/68F=2.5K ohms
50c/122F=.84K ohms
