When starting
boosted280
In the bottom right corner of megatune is a box that says "connected" it will grey out if megatune is not connected to megasquirt. Is that what you are seeing when trying to start? If so, then you probably don't have 12 volt power that is on during cranking and running. I may be mis-interpreting what you mean by "offline"
  On 1/25/2011 at 5:23 AM, lilt304 said:
Well the shop that wired it setup a new fuse block. And it is running to it.
I suspect they did it wrong then.
  On 1/25/2011 at 8:15 PM, mobythevan said:
Megasquirt has two power inputs. One constant 12 volts and one switched 12 volts. So the constant should have power all the time, like directly from the battery through a fuse. The switched should only have power during cranking and running.
Is this a new thing? I was under impression that MS only had 1 power connection, unless they have added it to the new boards. Settings are stored in NVRAM so it doesn't need constant power like a stock ECU.
