J240ZTurbo Posted January 26, 2011 Share Posted January 26, 2011 Hi, need to center the steering wheel on my z31 ss, does anyone know how to removed the from cover from a 1988 z31 steering wheel, I dont want to brake anything? thanks, J. Quote Link to comment Share on other sites More sharing options...
z2go Posted January 26, 2011 Share Posted January 26, 2011 Check the FSM. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted January 26, 2011 Share Posted January 26, 2011 If it's one without buttons on the steering wheel, the horn cover pops off. Pry at it. Quote Link to comment Share on other sites More sharing options...
jasper Posted January 27, 2011 Share Posted January 27, 2011 (edited) Unless someone has "uncentered" the wheel by removing it as you want to do, I would leave it alone. A WHEEL ALIGNMENT is the proper way to center the wheel. If someone misinstalled the rack, and failed to maintain the centered position, you need to center the rack relative to the wheel,done at the rack. Steering racks usually have a THRU CENTER "area" as manufactured. It's"tighter". This center position helps keep the car going straight down the road. It WILL also affect turning radius left to right, and may cause tire rubbing and,or suspension interference. Additionaly, sometimes the turn signal cancel clock positions can be altered by repositioning the steering wheel. I would do it properly. Edited January 27, 2011 by jasper Quote Link to comment Share on other sites More sharing options...
J240ZTurbo Posted January 27, 2011 Author Share Posted January 27, 2011 done thanks all. Quote Link to comment Share on other sites More sharing options...
