Guest kcambron Posted January 28, 2003 Share Posted January 28, 2003 I am just getting to the task of replacing my floor pans(GGRRRRR) and would like to know the easiest way to remove them. Will my frame "rack or twist" if I remove both of them? I don't want it to go down the road on three wheels! Thanks for the tips! Quote Link to comment Share on other sites More sharing options...
mobythevan Posted January 29, 2003 Share Posted January 29, 2003 I don't know what is the best thing to do, but I'll tell you how I am approaching this. I am only replacing one side at a time so that the car has the most amount of support left in the unibody. Also so I can square the new setup with the old framerails on the opposite side. Then sqaure the second frame rail from the first that was replaced. I am talking frame rails because I am replacing them when I do the floor as I suspect you will. I am using a combination of high speed cutter and air body saw to remove the old floorpans. Also I am doing this with the car supported by several jack stands. I thought about making a rotisserie, but decided the car would have more support on jack stands. Maybe I will put it on a rotisserie to finish some of the welding after everything is rigid. Good Luck Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 18, 2003 Share Posted February 18, 2003 Doesn anyone sels full floorpans? Quote Link to comment Share on other sites More sharing options...
Wagz Posted February 18, 2003 Share Posted February 18, 2003 Try here: Zedd Findings Quote Link to comment Share on other sites More sharing options...
mobythevan Posted February 18, 2003 Share Posted February 18, 2003 I am putting in the zedd floorpans. I have pics showing the fitting of the passenger side up on my website. look under 240z then under frame, new pics at the bottom. I am real happy with them so far. Quote Link to comment Share on other sites More sharing options...
