WTB: L28ET Oil cooler banjo lines
LanceVance
Looking for the banjo hard lines from a 280zxt automatic oil cooler adapter.
Rubber lines not needed, as I will be cutting off the crimped portion anyway.
If you've gotten rid of your banjo fittings, and still have these lines laying
around I could really use a good deal on these...
Here's a picture for the visual types...
Shipping will be to 79925 B)
Thanks in advance!
Are they a non-standard size?
They're actually M18x1.5, so it is pretty standard. Problem is, you have to angle the hoses up for clearance around the whole adapter. I had my hose guy cut my hard lines and weld on -10 fittings. I only realized afterwards that I would have to angle my new fittings almost straight up for them to work <_<.... So, long story short, I'm looking for new hardlines so I can have him weld the fittings on the very ends, to keep the lines going straight forward from the adapter.
I want to keep it banjo, not for any particular reason. I just think that with a fresh zinc coating, and black -AN hoses attached at the ends it will look really nice, while loosely maintaining a stockish look. Purpose made hard lines beat loose and messy braided in my book, just trying to keep it clean as possible under the hood. B)
