Factory timing camshaft?
Every thread I see about timing the camshaft on a L28ET says only to mark it carefully before removal at tdc (compression stroke) else you will be in a world of pain... so i did, yet now when installing resurfaced head I find that my brilliant mechanic must have wiped it off because I can't find mark at all! I've looked through the Chilton Manual, and browsed the forum and all I can find is warnings not to take off without marking... anyone know where I can find the procedures to return to factory timing? Is that possible? I'm kinda freaking out here.
It's an '83 motor if that matters.
