LanceVance Posted March 8, 2011 Share Posted March 8, 2011 I am currently having some machine work done to my valve cover, so I don't have access to it (nor do I have the appropriate measuring tools for that matter) but I need some measurements off one. I've been contemplating ways of using -AN fittings instead of the breather tube that doesn't involve having an adapter fitting between the cover and the fittings. I want as clean of a solution as possible, so I came up with the idea of drilling out the hole in the valve cover and passing a flared male -AN fitting through from the inside and welding it on the inside of the cover. With this method I can put a 45° female hose end flush against the valve cover, and all the welds would be conveniently hidden from sight! What I don't know is the size of the hole as it is from the factory, and what size hole I would need to drill to allow an appropriate sized -AN fitting through. Anyone with suggestions on what size -AN fitting (I'm thinking -8, but I'm not sure?) and what size hole I would need drilled out would really be appreciated! Quote Link to comment Share on other sites More sharing options...
cockerstar Posted March 8, 2011 Share Posted March 8, 2011 (edited) I'm not sure on the size of the stock breather hole, but here are some links for reference: AN thread sizes: http://www.gre6.com/ansize Corresponding drill sizes: http://www.physics.ncsu.edu/pearl/Tap_Drill_Chart.html Edited March 8, 2011 by cockerstar Quote Link to comment Share on other sites More sharing options...
