Flanges for SCH10 pipe?
BLOZ UP
I'm making some manifolds and want some type of flange assembly to connect the 1-1/2" SCH10 butt weld pipes to each other, so as to make the left bank, right bank, and collector sections removable. What can/should I use to connect them? The OD is about 1.8" or so. I'd really like to use v-bands, but the smallest I can find is with a 2" ID.
The plan was to use a 6-1 collector (I'm aware of its disadvantages), but should I just bite the bullet and do two 3-1 merges before the collector--placing some larger diameter pipe that has existing v-band assemblies inbetween?
Would regular old 2-3 bolt flanges be a bad idea?
What about just two 2-1 merges and a 4-1 collector (like a 2-1 on two cylinders with 480 degrees of separation)?
The image below is the manifold so far.
Edited by BLOZ UP
