billseph Posted March 23, 2011 Share Posted March 23, 2011 Wanted to know if anybody out there has run an 82 zxt dizzy with the internal CAS with an 81 ECCS and harness. I have the spindle and dizzy from an 82 and the harness connection for the 81 crank mounted CAS looks the same as for the 82 dizzy so I'm assuming I will work but wanted to see if I could get a definitive answer BEFORE I do the install. The car was setup with a non-turbo dizzy when I bought it and I was told that the CAS was suspected to be bad was the reason for the dizzy swap in the first place (by the way I have a 240z with l28ET swap) Thanks. Quote Link to comment Share on other sites More sharing options...
