Nigel Posted February 6, 2013 Share Posted February 6, 2013 Specs show the aluminum Z31 calipers at 9lbs with pads, vs 14lbs for the V6 4-Runner caliper. But the V6 4-Runner has 43mm pistons, vs 40mm pistons in the Z31 calipers. So, you could loose the weight advantage trying to run a large enough rotor (12"?) with the Z31 caliper to match the brake torque of the 4-Runner caliper, if that's your goal. But you'd have improved fade resistance with the larger mass rotor. Nigel Quote Link to comment Share on other sites More sharing options...
Wedge Posted February 7, 2013 Share Posted February 7, 2013 Thank you Nigel Quote Link to comment Share on other sites More sharing options...
