Grog Posted April 30, 2011 Share Posted April 30, 2011 Need some help folks. I have finally began working on my 280Z after putting it in storage back in 2001. I left off with replacing all the wiring and made some good notes, but now its show time. I have the correct Honda wiper motor, but just can't get this thing to work after reading all the posts, traing all the wiring, and it just won't work. My memory may be to blame also. Now, I am fairly certain that the stock delay module is shot. May be someone can help me understand a few things about the upgrade: 1. does it rely on utilizing the stock relay/delay module WITH the additional relay? 2. can the stock relay/delay module be omitted? 3. if #2 above, has anyone wired up the wiper motor successfully using new relays with the stock combo switch? 4. can anyone help me out with any of the above? Its really stumped the chump [me]. this is the last thing I need to complete on the entire electrical system and it has me beat. Quote Link to comment Share on other sites More sharing options...
AkumaNoZeta Posted May 1, 2011 Share Posted May 1, 2011 I have a 260Z that I put a Honda wiper motor in. I couldn't find a way to use the original switch and wiring because all the instructions I've found were for 240Z installation which only has Off, Hi, and Lo unlike the later models having the intermittent. I got rid of the module and used a 20/30 relay and have it working with a universal 3 position switch and plan to get a 240Z wiper/headlight switch sometime. Quote Link to comment Share on other sites More sharing options...
Grog Posted May 3, 2011 Author Share Posted May 3, 2011 I am facing the same decision. I thought there was one or two people that got the 280 relay to work, but no one else has weighed in. On to plan B. Quote Link to comment Share on other sites More sharing options...
rjstcroix Posted May 6, 2011 Share Posted May 6, 2011 Hey, This might help if you haven't already checked: http://atlanticz.ca/zclub/techtips/wipermotor/index.htm Regards, RSC Quote Link to comment Share on other sites More sharing options...
