Does autometer mechanical speedo work on rb25 transmission
I found a cheap 5" autometer speedo mechanical gauge and was wondering if anyone had made it to work with with their rb25 transmission. I had seen the electrical type work, but not yet seen the mechanical on the autometer. If i do end up getting it, what speed cable and speed sensor will I need to get? I have a z31 3.7:1 LSD in my rear end btw.
It wont just work, if at all. I think the ecu needs to have an rpm signal and you would need a mechanical speedo gear to use that tach.
Basically, Im pretty sure it would be a lot of fussing around if it even would work to save a little money.
Edited by jakeoster
