Cranking pulse width settings
Kali
Currently trying to set up my MSI V2.2 i have a mild VE table and most of the info has been filled out. But im having some trouble figuring out what the Cranking Pulse Width needs to be set to in the enrichment settings. Current upgrades as follows:
Block:
* F54 L28et turbo block
* JE Forged Pistons and rings 89mm
* Mechart A-Beam Stainless Steel rods
* ARP Rod Bolts
* Diesel Maxima Crank
* ARP Head studs
* SCE 2mm Solid Copper head gasket with sealing rings
* Nismo single groove dampener w/ Nismo front crank bolt
* 83 280zx turbo oil pan
Head:
* P90 Head off 82 ZX turbo
* Schnider Cam Lift(In/Ex): .460/.460. Duration(In/Ex): 270/280.
* Schnider matching dual valve springs, retainers, lash pads, and rocker arms
* Ported polished
* 5 angle valve job
* Resurfaced and decked combustion chamber and intake/exhaust side
* N42 non-egr intake manifold
* 420cc injectors
* JSK Fuel rail w/ Autometer pressure gauge
* T3/T4 Turbo
* 2.5" exhaust
* Z32 MAF
* 83 280zx dizzy
* MSD 6A
* 2.5" thick innercooler
* 2.5" innercooler piping
* MSA BOV
* Walbro 255lph
