Neverdone
  • Days Won
    24
Posts posted by Neverdone
  1. If your budget is 150k, then why are you asking us? Ask the fab shop that is going to be doing 100% of the work.
    If you want the "Wow factor" of a V12, and something to make it special, go get the M120 V12 out of an S600 and straight pipe the thing. People have made them sound like Zonda's.
  2. You can absolutely source an aftermarket clutch/brake pedal assembly. Wilwood makes them. You'll probably have to do some math though on how much pedal travel you have, vs how much your clutch master and slave cylinder are outputting to make sure they'll work.
  3. So you have an engine. Now you have no means of mounting it, so you need custom mounts. Now you have no means of mounting the transmission, so that's custom. Now you need a new custom driveshaft to put that power to the rear wheels. Now you need to upgrade the diff because the R160 diff it comes with is tiny and is not meant for that kinda power ALL to the rear wheels. Now you need new axles.
    So you've got the engine physically mounted now, great. Now you gota turn it on. Now you need a new wiring harness that'll adapt to the chassis components and the engines ECU which hopefully comes with the engine. Oh it doesn't have the ECU? Now you gota learn megasquirt and deal with all that shit because an actual standalone ECU that'll do what you need it to do is well over 5 grand.
    Now you need new gauges because the ECU you have doesn't want to talk to the ones in the Subaru unless you can pull off some slick electric engineering. Since you just dropped THOUSANDS on this damn car, you're gonna want some suspension components to go along with this because you'll be damned if this heavy beast can't really corner for shit.
    Now it's 10 years later and you're staring at this damn thing which doesn't run either at all, or poorly, and you're wondering, "Why the hell didn't I just change the head gaskets and buy a bigger turbo for the stock engine? I'd be done years ago!!!"
    More time goes by, you finally kick your alcoholism that you needed to cope with the neverending torment of this unfinished project and you get serious and put in some serious money to just get the damn thing working. It finally turns on, everything is working just fine. You go down your street...and you realize it's not any faster at all then a freggin stock Forester turbo. Darkness sets in.
  4. The easiest way to get to 9k is to take the L28 out, and replace it with a Honda F20C or Mazda 13B Rotary engine.
    The next easiest way is to throw 10's of thousands of dollars at an L28.
    There might be a 3rd way but I'm not aware of it.
  5. The price and popularity of S30's has been going up for a while now, well before the 400z was even officially announced that they were going to make it.
    With more and more cars becoming numb, fat, and auto-only, there is going to be a shift back into older cars that aren't necessarily as fast, but are perceived as "more engaging".
    Add in that the S30 is beautiful, and is becoming more and more rare due to many of them having been fully rusted away or crashed into trees, and the price goes up.
    Until the price of gasoline becomes absurd (i.e. 20 dollars a gallon or more), I don't see the prices of these going down any time soon/ever.
    The people on Bringatrailer with too much money have definitely shot the price up faster than anyone could have ever imagined.
    • Like 1
  6. Due to the way it's mounted, (and it would be hard to mount it reversed due to fuel inlet location and possibly exhaust clashes) it seems like you'd absolutely have to run either fuel foam (fuel safe says it must be replaced every 5 years maximum) or run some sort of fuel surge tank if you're doing any sort of hard acceleration or cornering...which is kinda the whole point of the car.
    As this is the plan I have as well...I guess it's time to start looking into surge tanks!
  7. My biggest gripe is the design decision for the 300zx style taillights, on a car, that is doing everything it can to take inspiration from the S30.
    The hood, headlights, front end, side, rear quarter, almost everything is S30...then someone crammed some 300zx taillights on there because he liked them.
    To me, that's dumb. Make a modern version of the S30 taillight structure back there and actually have it be a cohesive structure.
    The front is pretty easy to fix IMO. I'm blow away at how a simple painted line really changes that whole space. But the taillights...that'll take a lot of expensive parts to fix that. I dunno. Maybe it'll grow on me, but right now I'm not a big fan.
    2020_nissan_400z-14.jpg?width=1024&heigh
  8. That front end's gonna need some work before they release it.
    It's *fine* as is, but it could definitely be a lot better.
    Also, Nissan would be smart to offer a ducktail spoiler for this thing.
  9. There is nothing magical about any engine.
    If you're going to go standalone ECU, and get one with enough inputs and outputs, then you can control any engine out there, and every feature it could ever have.
    I believe the Maserati uses a Bosch ECU, so more than likely all their sensors are Bosch if that's the case.
    Do your research, do some more research, give up, come back and do more research, and then eventually just pull the trigger on one that seems to have everything you would need.
