Conedodger
  • Content count
    52
  • Donations
    0.00 USD
  • Feedback
    0%
Community Reputation
0 Neutral
About Conedodger
  • Rank
    Regular
  • Gender
    Not Telling
  • Location
    Reno/Tahoe and Sonoma
  1. Injector choices
    And then I did this today... Hoke Trigger Wheel on Professional Products dampener.
  2. List of Options for Crank and Cam Position Sensors
    Sorry, Professional Products...
  3. List of Options for Crank and Cam Position Sensors
    FYI, MSA just called me yesterday to tell me they got their shipment of the Performance Industries dampeners and wanted to know if I was still a go. Well ya!
  4. Injector choices
    Yes. 440cc.
  5. Injector choices
    Using that excellent resource from NewZed, I have picked out some high impedance EV1 injectors that fit my calculated specs nearly perfectly. I discovered when researching them that they even have a nickname! Green Giant injectors!
  6. Jeep Cam angle sensor for L - Series
    Got a part number or a year and model? I think I'm going to run with this too. Might as well take advantage of all the tech I can with this.
  7. Injector choices
    So apparently, if I use the Supra injectors, they are high Z and don't require resistors. One of you says 10mm and the other 11mm rail though?
  8. Injector choices
    Whoops!
  9. Injector choices
    On a slight High jack of my own thread, will MS3X fire the stock cold start injector? And yes, I realize that's not the original.
  10. Injector choices
    I don't think so. I'm just putting together choices. You're the second to suggest this. As a bonus, a good friend is a Toyota parts manager!
  11. Injector choices
    Thanks MS3X
  12. Injector choices
    I calculate my new Rebello engines injector needs at 29.4# or 309cc. What have you guys used or can you suggest a reference. I'm just looking for options and opinions on what works. I have one suggestion from one of our Canadian members and I may go that direction but I always like to compare and contrast.
  13. PALLNET Throttle body spacer kit
    I'm using one of the TWM throttle bodies on an early non-EGR L28 manifold. The throttle body bolts right up to the manifold. Is there an advantage to spacing it?
  14. Jeep Cam angle sensor for L - Series
    Jacky, I'd love to see pictures of your build. Especially the Bosch MAF. I did manage to get one out of Ireland. So it would be cool to see how you set yours up. I was thinking I'd put a silicone house from the throttle body to the MAF, then more tubing, either stainless or silicone to in front of the radiator.
  15. Its running. But confusion about tune file
    What version?
