Stevotello
  • Location
    Georgia
Recent Profile Visitors
4092 profile views
Stevotello's Achievements
Newbie
0
  1. As the title says, mine is cracked and leaks whenever I fill up. It should fit the larger 77-78 style tanks. I'm not looking to spend too much just wondering if anyone has an extra or one in a parts car that they dont need. Thanks
  2. Looking for the piece of metal that the distributor mounts to in a 280ZX. An earlier generation mount will not work as I already have one and am converting to a newer distributor.
  3. Just looking for a used functioning male hood latch for the s30 chassis. All the ones I've found on ebay are replated and extremely overpriced.
  4. Just seeing if anyone has one on here before I go buy one from ebay, let me know.
  5. Looking for a relatively cheap turbo to put on my stock '77 n/a motor. Nothing too big so turbo's like the stock T3, holset HY35, or anything aftermarket. Let me know what you have.
  6. I've already got the turbo distributor, and I found a pump I can use, so all I really need is the drive spindle.
  7. Building a turbo motor with turbo distributor and looking for both - message me if you have either
  8. I PM'd everyone that I could drive to in a reasonable amount of time, but I'm still looking for someone that is not as far away. If there's anyone within 100 miles of atlanta area that has one please let me know
  9. My L28E N/A has a cracked block and am looking for a cheap complete L28ET to swap my old engine with. Let me know what y'all have.
  10. As soon as I can find a cheap turbo motor and swap it in, know anyone that's got one?
  11. The thing is the Z ran fine before winter got cold around the end of November, and literally nothing could have touched it in between now and then. The only factors involved are the freezing weather and time, so I find it hard to believe that the head gasket could have just deteriorated over a 3 month period of simply not being used. I don't want to spend the time removing the head to find out what could be an irreparable issue. Really all I am wondering is if there is something else that I am missing other than a blown/split head gasket or cracked block that would yield the same symptoms. Because even if the head gasket is blown, my time would be better spent swapping in an l28et than taking down my current N/A and replacing the head gasket.
  12. Over the entire winter here in Georgia, I left my n/a 280zx alone and hadn't driven it for a few months. Previous to the winter, the engine ran pretty strong and there weren't any issues I could think of other than the exhaust manifold gasket leaking a little. However, this winter, temperatures were especially cold and I suspect that the antifreeze had frozen and cracked my block. When I went to run it this afternoon and take it for a ride, coolant sprayed everywhere in the engine bay on the driver side. At first I thought it was nothing and that one of the hoses were cracked, but after inspecting for awhile I couldn't find any cracked hoses. There is a distinct "puffing" sound coming slightly erratically, white smoke coming from the exhaust pipe, and coolant coming out of the exhaust pipe. Is it safe to assume that the block is cracked and time to finally do an l28et swap? I'll attach a video of the engine running now and one of it running sometime in the fall even though that is probably irrelevant. Now: https://www.dropbox.com/s/h3wd8t033r7wtcj/20140222_135403.mp4 Before: https://www.dropbox.com/s/kvplhep6pabaae7/2013-08-24%2020.38.34.mp4
  13. As the title states, I'm looking for an original 280zx driver side mirror in no particular color or condition (preferably white for convenience) but I'll take anything as long as there are no major cracks. Luckily my '82 ZX was missing only that and everything else seems to be good and in order now. Thanks, Steve
