Sign in to follow this
sid240z
S14 nissan ka24de into s30 wiring? Please help!!
Hey guys so I finally decided into dropping in a ka24de into my z for the sole purpose of it being a track car. I know the 510 guys put ka in there's cars all the time, an I've googled, check on ratsun and other forms and can't find how a decent write up on how to wire it. I know you can wire it to run on just two wires but how?
Share this post
Link to post
Good luck, I'm doing research as well. Let me know if you find something or figure it out, and I'll do the same. I do believe there's a small write up on ratsun titled somewhere along the lines of  "Wire SR/CA/KA into anything" and it looked like a circuit board with relays power and ground. I even think there's a video on it. Other than that I wouldn't know where to buy it. I was thinking of doing the swap mounting the engine and everything else then tow it to a professional shop and have them wire it up independently.
Share this post
Link to post
I was just looking at that and the wires that plug in to the Ka Alternator are both the same size one is white/red and the other is yellow. How do I know which one to connect? Also I connected the large white wire and black wire (power and ground Im guessing) from the stock Z alt. wires to the Ka alt. I guessing that would work just need to know which plug-in wire to use. I'd also like to say sorry about being retarded when it comes to electrical things
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
