lt1 alternator only mounting thought
ok the more i think about it and more diagrams i look at the more i want to do something about it
Look at this diagram:
now, why do people gut the power steering pump to use as a pulley? Why not just completely remove the power steering pump
THen, get an AC delete pulley kit(all over ebay) and route the belt from the top of the crank pulley under the tensioner, up to the alternator, down around the ac delete pulley and back to the bottom of hte crank pulley, hopefully clearing the tensioner???
This was my idea...any thoughts?
...get an AC delete pulley kit(all over ebay) and route the belt from the top of the crank pulley under the tensioner' date=' up to the alternator, down around the ac delete pulley and back to the bottom of hte crank pulley, hopefully clearing the tensioner???
This was my idea...any thoughts?[/quote']I don't think you can go from around the ac delete pulley back to the bottom of the crank pulley without hitting the tensioner.
Maybe you could go from the top of the crank pulley under the power steering pulley (or a fabbed up idler) around the alternator down to the delete pulley around the tensioner and back to the crank. Mine was routed something like that before I added the compressor.
Here is a picture of how I set mine up.
I agree with Bart, I don't think it would work to go under the tensioner, up to the alternator, down to the AC delete and then finally back to the drive pully. I'm pretty sure the route back to the main drive pully from the AC delete is going to interfere with the tensioner.
Wheelman
Guest DaMeat
I finally finished my alternator mount Nazar, I used an alternator from a mid 80's Suzuki I believe... (It might be a Subaru?). I didn't pay attention to the car I pulled it out of at PickNPull.
I used an aluminum block, about 3" x 3" x 4.5" and machined it to mount on the front 2 bolt holes by the harmonic balancer. All I used was a table saw and a drill press to cut and drill the aluminum block into the right shape... Block cost about $13 from a scrap metal place, they even cut it to almost the right size for me and charged me $4 a pound...
Check here for the alternator I used:
http://www.balmar.net/PDF/Alternator-Regulator%20Guide.pdf
It believe it is the top most one in the PDF. The Model 70 Series... It is small and fits in front of the motor mount with enough room around it to tension the belt...
The problem with this swap:
Only 55 amps output... I think this is what these alternators are rated at so you don't get the 110 amp monster but I will put a regular car stereo in it and I think it will be fine.
Uses only 4 of the available 6 ribs of the damper... but after 300 miles it is holding up great so far and the mount is EXTREMELY solid. No movement at all... I might have a new pulley machined for the alternator so I can use a 6 rib belt but that will be a few months off... Also I want to go back and polish and clear coat my bracket so it looks even nicer!!
The good about this swap:
It only cost about $75 all together!! for the alternator, the aluminum block, the belt, 2 stainless steel allen bolts to mount it with, and a tensioning rod.
Lose quite a few pounds by not using that big *** bracket/pulley/"delete this pump" setup and the alternator is nice and down low so it cleans the motor up quite a bit I think.
I am pretty happy so far with it, and it seems to work great.
I will try and get some pics of it in a new thread within a couple days... If not my 240Z is going on a boat to be shipped to Holland Friday morning and it will be a month before I can get pics of it... (It takes a month for the boat to get there...)
