mldub2
Everything posted by mldub2
  1. There is only 2 vent lines coming from the car and the tank has 3.Can i cap 1 off or what do i do. So it is okey to run the 240z tank on my 280z?
  2. So i can just delete them and what is this? Do i need it.
  3. I am trying to put a 240z fuel tank in a 280z. Because when i bought the car it did not have a tank in it. My question is were does the outlets on the right side, back, and left forward go to and the the other forward ones that are close together are the fuel lines right? back forward
  4. and i dont see any green and red with around it.
  5. I am just trying to hook everything up and i am so lost with this part of the swap. I am still confused on what u said.
  6. I need help with my wiring. On the 75 280z wire harness it had the resistor(thats what i think it is. on the left of the picture)hooked up to the 280z coil. I removed the 280z coil, hooked up the 81 280zx coil to the ignition harness. Now do i conect the resistor to the coil? and what is this?
  7. I looked on the FSM and did not find anything about it.
  8. Just put in on with out the plates and it looks good. Thank you so much for your help.
  9. OKey what about a plate between the flywheel bolts and the flywheel itself.
  10. I am going from auto to manual tranny. Here is my question. When i took of the flex plate it has 2 plates on both sides of it. when i try to install the flywheel with the 2 plates the bolts are short. Are the plates only for the flexplate because its thiner or are manual tranny blots longer.
  11. Okey now looking for 71 to 75 gas tank.
  12. I need a 75 280z gas tank with sending unit in good working shape asap. My email is mwhitby85@gmail.com
  13. Is it okey to change one piston that has a different head marking. From 34 to a 45, both are from a l28et.
  14. I need a 280zx turbo timing chain cover.
  15. If you are looking for a oil cooler. There is one on ebay for about $40 with the adapter
  16. Yeah he can send pics. I was going to post them, but he sends it as a slideshow.
  17. yea i had to pass it up. It was full of rust and a 2+2. For chopping it up i would not know were to start. So still looking for a car.
  18. i found a 77 original fairlady z RHD but it needs alot of work, body wise. the interior is all there but also needs work. my question is what is the diffrence between the fairlady and american z if any. I will try to post pic soon.
  19. when i get the other piston should i use my rod or the one it comes with. If it even matters
