sta
  • Gender
    Not Telling
  • Location
    Massachusetts
sta's Achievements
Newbie
0
  1. Comparison between headlights and light bar. headlights: Light Bar:
  2. I swapped out my factory lights for new hellas and wired the lights off of relays to eliminate resistance and voltage drop from the factory switch. Quality was mediocre at best compared to modern lights. I decided to try something different and mounted an LED light bar in the radiator opening. I have a g nose car so I only have the lower opening. This is what I installed: https://www.superbrightleds.com/moreinfo/eclipse-series-off-road-led-light-bar/30-off-road-led-light-bar--90w/1489/ I wasn't sure what to expect, but if anything they may be too bright. Night driving on back roads will be fantastic, however I will not be able to use them as driving lights. I was concerned that blocking some of the radiator opening may have impaired the cooling system, but that does not appear to be the case. That being said it was in the 50s when I went for a drive Sunday.
  3. Attended a Japanese Car Show at the Larz Anderson Museum.
  4. sta
    240zg
  5. MY 73 240zg. Purchased in 2009 rusted and worn out. Finally back on the road with new almost everything.
  6. Parts were received as described and expediently from Bob a.k.a. Jellobob Thanks Bob. Steve
  7. Parts have been sourced. Thank you for all the PMs.
  8. Hi All, As stated above I need a pair of 27 spline 280Z companion flanges. I am located in Boston MA. Thanks, Steve
  9. I have run into the same issue. I purchased the right side remanufactured z31 CV half shaft through an online parts store, and I have located a driver's side from a used parts source (junkyard). A1 Cardone will remanufacture the drivers side CV halfshaft if you provide a suitable core to work from.
  10. Barstool Sports ran Erica as the wakeup girl this morning: http://boston.barstoolsports.com/hot-gallery/wake-up-with-erica-ocampo/
