        z1 zonly
                Posts39
Everything posted by z1 zonly
	Epoxying injector bungs into a plastic manifoldz1 zonly replied to z1 zonly's topic in Fuel Delivery Seems like about the same end result as bonding in a bung, no? And it'll be difficult to get a nut on the back side at a ~30-45deg angle to the runner.
	Epoxying injector bungs into a plastic manifoldz1 zonly replied to z1 zonly's topic in Fuel Delivery The difficult thing is that there are no injector bungs. These models had their injectors way down in the head and no bungs on the manifold. I need to add some for my project. Not sure I can get away with mechanical fastening, because I just don't know how much material there is to deal with, particularly at an angle to get injector spray parallel to the intake charge. It's a $300 gamble to get a manifold and find out. Argh...
	Hi all. I'm interested in drilling and epoxying/plastic welding/otherwise bonding injector bungs into a Porsche Cayenne manifold, which is made of plastic. I've Googled around and see that there's precedent for epoxying bungs into aluminum manifolds, but it's difficult to find for plastic. Is this a reasonable and safe exercise? Can i use any old aluminum injector bung, or should I make sure it's of a similar material? Here's a pic of the manifold in question:
	Twin cam head for the L6 from Derek at Datsunworksz1 zonly replied to Derek's topic in Nissan L6 Forum Congratulations, Derek! Remarkable job. You, sir, are a hero.
	Brief follow-up on this for the benefit of future searchers. I ended up using an Infiniti J30 intake balance tube that I had lying around. Same ID and OD and plenty of varying bends to help you route it. Got my tube built and am on to the next project!
	Good call, 1969honda. Done. Thanks. Interesting z-ya. As I mentioned in the first post, the Z32 one is the same dimension as the VH45, so I think it's safe to assume that all early 90s-era Nissans used the same tube material.
	Anybody? I'm ready to get to work!
	http://www.ebay.com/itm/AG025-ENGINE-OIL-PICKUP-TUBE-2002-CHEVROLET-SILVERADO-2500-6-0-/151253714435?pt=Motors_Car_Truck_Parts_Accessories&hash=item23376c8603&vxp=mtr That one's looking really nice! Just eBaying for pickup tubes from random vehicles, they all look very very similar. What are the chances they're acceptably similar diameter and wall thickness for about everything?
	Hi all, I need to extend a VH45 oil pickup tube for a rear sump oil pan. The stock pickup tube is very short and I can't just tack multiple straight sections together. A Z32 pickup tube has the same dimensions and some nice bends, but the length has a flat spot in it for clearance. eBay link for reference: http://i.ebayimg.com/00/s/OTAwWDE2MDA=/z/RnAAAOSwY45UPKZY/$_57.JPG Anybody got an idea for what I could use? I have an LS1 one lying around that looks really close per eyeball, but I need it and don't want to cut it up. At this point, my best idea is to use a length of straight tubing with the same dimensions and a Z32 one for the bends.
	Recessed engine mounting (into the firewall)z1 zonly replied to z1 zonly's topic in Fabrication / Welding WOW, it's just amazing/creepy that you would bring this thread back. I'm finally getting ready to do this. Have the engine (LS1), have the transmission (Tex SR1 4-speed dogbox), have the stripped Z32 chassis, just need a bellhousing before I can start hacking. On Sunday I was searching around on Google for bellhousings and just happened across your website. I then spent a significant amount of time there. You've done a fantastic job on that car and it's truly an inspiration. Particularly that bellhousing--DROOL. Thanks for responding here--I may have to PM you as I get further into my build.
	Sounds perfect, except we didn't get the Renault 25 in America. The Audi gearbox I was alluding to earlier is the same premise--front engine way out in front of the axle, except AWD with front axles bolting to the box and an output shaft for the rear drive: Wondering if any other gearboxes that could hold the power have the axle bolt-up configuration or if I could plug the rear of the Audi transmission.
	Recessed engine mounting (into the firewall)z1 zonly replied to z1 zonly's topic in Fabrication / Welding I've seen the Uncle Joe's car floating around the Internet and saw they had LS1 swapped it. Although I'm not positive, I think firewall mods are necessary on LS1 swaps in Z32s just as a cost-of-doing-business for getting the engine in the car. My VH has a football field between the engine and firewall, meanwhile (which is the impetus for wanting to move it back). The transmission is in the stock position. That's a really interesting tidbit on the 510. Gah!
	Recessed engine mounting (into the firewall)z1 zonly replied to z1 zonly's topic in Fabrication / Welding That's what they've been doing for the past several years; key word being "almost," heh! Go McLaren! Anyway, same conclusion, wait until I befriend a setup genius. Thanks for all the replies!
	Recessed engine mounting (into the firewall)z1 zonly replied to z1 zonly's topic in Fabrication / Welding Just a trackday car, no competition. Building is the funnest part for me, so time doesn't matter so much. I just want to build an extreme car and have a blast personally to reap the accomplishment. But I certainly won't be having a blast if the car doesn't improve markedly after such an intensive effort. Hence the thread.
	It really is the most awful looking car ever. I chuckle every time I see it. I need to do something with it--it's just been sitting in my yard. But man, it's hard to get motivated to work on it when there are a lot of other projects on my plate. I think I've settled on a transversely-mounted 4-cylinder engine in the back. Although I still want to do some research to see if I can find a gearbox to do a longitudinally-mounted engine in the rear (e.g. Porsche, but way too expensive; I was thinking Audi), in which case I'll use a VG30DET/TT, which would be preferable. On that subject--can I use an AWD gearbox for an Audi (where the "front" axles bolt to the gearbox) and simply plug the rear output shaft hole to run a longitudinally rear-mounted engine?
	Recessed engine mounting (into the firewall)z1 zonly replied to z1 zonly's topic in Fabrication / Welding Ablesnead--Carolina Motorsports Park (CMP) in Kershaw, SC. I'll let the others conjecture about your second post. Thanks for your input!
	Recessed engine mounting (into the firewall)z1 zonly replied to z1 zonly's topic in Fabrication / Welding Racetrack. My local track is tight, but Road Atlanta and VIR aren't far away either. VH45DE Z32, by the way.
	Recessed engine mounting (into the firewall)z1 zonly replied to z1 zonly's topic in Fabrication / Welding So is there an 'ideal' target for MOI weight positioning, or is it a moving target, or solely a function of setup?
	Recessed engine mounting (into the firewall)z1 zonly replied to z1 zonly's topic in Fabrication / Welding So, the closer to 50/50 F/R weight bias, the less predictability and more skill it takes to drive at the limit? Gotta say, that upsets my intuition. I guess that's why I'm a bean counter and not an engineer . Perhaps I'll leave it woefully front biased until I become good friends with a setup guru. Sigh.
	It's been a long term goal of mine to mount an engine way back into the firewall--literally into the cabin. For example: I'm confident that I could actually accomplish this now, but I recognize that it creates a whole slew of jobs that need to be done simultaneously--moving the driver position back just as far, rebuilding the floor, brake lines, etc. etc. It's far more than cutting out the firewall and mounting the engine back a foot or two. I'm wondering if the ends justify the means. Searches have yielded little on the actual results of doing this. It was rumored that the S14 pictured above ran slower lap times than other similarly prepped (but normal engine position) 240SXs, but there was no evidence of that. The only reliable account I've seen was from the builder of the above Supra. He said that on the track the car had great turn-in, but was unpredictable on corner exit, and essentially said the car did not feel as balanced as he had expected. He said he would be attacking the suspension geometry, but never reported back. So does anyone have any evidence that a SUBSTANTIAL (12+in.) engine setback would substantially positively impact performance driving conditions? I'm wondering if front engine cars simply don't work any other way...
	I'm feeling less worried about it. I bought some cheap oil and good filter and will change it after the first few heat cycles. Hell, even if it lunches the bottom end, the hard conversion work is done . Bright side, bright side. Just finished installing the engine and transmission. Lots left to do, though.
	The engine hasn't been started. The sand entering the engine was a result of an oversight on my part while attempting to customize an oil pan (which I've since abandoned). What I did tonight was clean the bottom end as well as I could before installing a perfectly clean stock pan and pickup tube. My worry is about lingering particles of sand in the bottom end that I wasn't able to clean (from the aforementioned mishap).
	Need some help here guys. I bought this car for one reason and one reason only: it's hilariously hideous. I parked by it one day, left a note on it that I had to have it, and took it home a few months later for $400 (and it's actually in really good shape!). But now that I have it I don't know what to do with it. My first inclination was to make it a wheelstander. But I'm moving away from that--too one-trick-pony. My only requirements are that it remain street legal and that it stay looking stock on the exterior (this is THE best sleeper platform I've ever seen). My two biggest choices are 1) drag/powerful street sleeper orientation or 2) track hoe. Number one would entail a V8, probably turbo, mounted longitudinally in the back. Number two would be either a motorcycle engine or Honda engine mounted transversely in the back. My only problem with it being a track car is that it's the worst possible platform to start with--it would require pretty much reengineering the entire car from scratch. Not that the drag setup wouldn't have its fair share of challenges, but going just short of a tube frame seems like a lot of work for an '88 Stanza. Anyway, enough rambling, here she is in all her glory.
	I'm wrapping up a VH45DE swap into a Z32. I started several years ago by attempting to build a rear sump pan. At one point I sandblasted the pan. I thought I had cleaned it as well as I could before mockup, but it still dusted a bit of sand into the bottom end. Fast forward several years and I'm finishing up the swap, this time with a stock VH oiling system. I sealed the pan tonight (no rebuild--this is a good condition engine), and cleaned up any foreign debris as well as I possibly could. I still have a lump in my throat that this could be a big problem. Is there anything I can do to alleviate this? The only ideas I've had are to fill the engine with mineral spirits and turn it over with the starter several times before draining it and filling it with oil. Or filling it with cheap oil, run it at idle for 30-60 seconds, then change the oil and filter. Is it even going to matter? Definitely screwed this one up .
	VK45 and other Nissan engines oil-consumption issue?z1 zonly replied to z1 zonly's topic in Other V8Z Tech Board Verrry eeenteresting. Thanks Mag!
