lester
About lester
  • Birthday 01/28/1992
  • Gender
    Not Telling
  • Location
    Millbury, Ohio
lester's Achievements
Newbie
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
0
  1. Z240-thanks for that link, according to that they are the same. Very helpful link I will defintely be bookmarking that one. Dangerdan- if you wouldn't mind confirming when you get the chance I'd appreciate it
  2. I did some research but can't get a definite answer from what I found. I have a 75 280z 2+2 that needs a rear bumper (big dent on the corner of it). I have found one that is off of a late 260z (same bumper as the 75). My issue is I'm not sure if the 2+2 and the coupe had the same bumper or not. I know the rubber corners are different as mine have the 2+2 marked on them, but are the chrome bumpers different lengths? Would hate to buy this bumper and not be able to use it. Thanks in advance.
  3. Thanks for the quick response, if I don't get anyone else with a confirmed working one ill pm you. Thanks again.
  4. While driving my 78 2+2 yesterday pretty sure my booster gave out as I lost my pedal and have no leaks that can be found. Also found that the rpms die anytime I hit the brake pedal. In search of a booster for a 2+2. Pretty sure the coupe booster is different so specifically looking for a 2+2 booster. Thanks
  5. I actually just set mine up the same way a few weeks ago and am curious to see what other say. My z is a 75 and I believe the bracket is a bit different as my pump sits up a bit higher.
  6. Alright awesome I for sure will use the front then, and will probably look into buying new stuff for the rear. Not sure it will sit right if it lowers it 1 1/2 in the rear and not the front .
  7. Will the front struts,springs, and control and tension rods fit, or are they different too?
  8. I've done quite a bit of research but have yet to come up with an answer. I recently purchased a 3/74 260z that had an almost brand new suspension under it. Brand new eibach springs, new struts, new bushings all the way around, and stripped and painted very nicely. This car was way too far rusted to be worth saving so I took out the entire suspension and kept it. My question is will it swap directly into my 78 280z 2+2, or am I better off selling off the suspension to purchase one for my 78? I have seen where some people said it is possible, but are there any modifications that will need to be made? Also does having a 2+2 make a difference? Not sure if the coupe and 2+2 had the same suspensions or not. While I am at it I am planning on swapping my tranny out for a 5 speed, and hoping to find a 3.90 rear end to throw in as well. Any insight is greatly appreciated.
  9. Sent him a pm. Thanks Jamal
  10. Markers are blowing out, so believe I could be the switch..looking for a cheap working one just basically to do troubleshooting. Thanks
  11. Looking for a headlight switch for a 78 280z. Having a problem with my markers blow
  12. Got tired of blowing fuses, so decided to try a tip I found searching online to hook up a 12v light in-between the contacts without the fuse in place. If there is a short the light will light up, which it did. Then you go around and remove bulbs and jiggle wires until there is a change in the 12v light to see where your issue is. I then went around removing all the markers the turn signal lights and ect. Jiggled wires everywhere but still can't find my issue. Thought for a bit that it was the dome light, so took it out to find it very hot to the touch, and the wire pretty burnt and chrispy. Fixed this issue but still wasn't my issue as the 12v light didn't change one bit. I tried other places like the glove box light the engine light, and just about everywhere I could think of that runs to that fuse to no success. Any one have any suggestions? I am totally stumped-Just wish I could find this issue soon so I can drive my car at night again.
