300GTE
Everything posted by 300GTE
  1. both turbos put out 15psi, the boost doesn't double just the airflow.
  2. Don't know about the power glide bud here is a reference to alot more common GM street transmissions. Don't know how to resize, so mods if need be just make this a link instead. Thanks Hope this helps.
  3. I just wanted to share this tid bit of information that i came across in my search for wiring diagrams for my 86 300zx n/a coupe, that i am currently installing an 18 circuit "Painless" wiring harness in. The site is www.adhol.com. I know there are those of you who wish to replace the harness, or harnesses throughout your car, and are unfamiliar with the wiring of your particular vehicle this seems to be a place that would be of great help . I just wanted to share this, as I figured it would benefit the community, FYI I got the wiring diagrams for my complete car for under $10.
  4. i think you were right there is no movement inside the valve cover.
  5. my oil level was full the oil actually is quite clean.
  6. Is the oil pump driven by the timing belt? I asked this because, the oil pressure gauge shows no oil pressure while trying to crank the engine.
  7. I just bought it and it wasnt running due to an accident the cap and rotor was smashed by the hood.
  8. help, i have an 86 300zx na, with a no start condition, the engine rotates fine , when the key is turned to start but, but engine makes no attempt to run for any length of time. the engine has had a full yune up today, spark plugs, wires, cap and rotor, and coil are all new. any helpful info would be appreciated.
